The AT-RT Driver Collectible Figure features expertly applied weathering effects to highlight the grit of the Remnant forces. With a newly developed worn and battle-damaged helmet and weathered armor layered over a hyper-realistic flocked coat to protect the Stormtrooper in the harshest of cold weather operations. To ensure the driver is ready for combat, the figure comes equipped with a DLT-20A blaster rifle and an SE-14r blaster pistol.
The imposing 1/6th scale AT-RT Collectible has been brought to life with meticulous paint applications and realistic weathering effects. The walker is rusty and battle-worn showing damage and wear on its steel gray exterior and Imperial crest. Measuring an impressive 60 cm (23.6") tall, the AT-RT features USB-powered LED light-up effects, realistic wires and antennae made of metal, and a newly developed mechanical structure boasting 10+ points of articulation, including adjustable mechanical legs and a front blaster cannon. The driver’s seat comes with articulated grips and footrests perfectly scaled to fit the AT-RT Driver figure. For display versatility, the vehicle includes two pairs of interchangeable hydraulic cylinders to accommodate different dynamic postures.
Add the Imperial Remnant AT-RT Driver™ and AT-RT™ 1/6 Scale Collectible Set by Hot Toys to your Star Wars™ collection! Pre-orders are open now, via Sideshow.com.
